high pressure fuel pump
Old Oct 20, 2009 | 09:46 AM
rbazemore's Avatar
Default high pressure fuel pump
Anyone experience misfire problems assocaited with a bad high pressure fuel pump? I am having to replace mine and the cost is over $1200.
thanks
Old Sep 1, 2010 | 12:14 AM
andymish's Avatar
Default fuel pump
That's dangerous bro. Well, at least you did replace it immediately. Always try to double check your fuel pump assembly once a week in order to avoid it before it's too late.
Old Sep 3, 2010 | 06:05 PM
MartyJ's Avatar
I had mine replaced under warranty after 1 year. Now Mini has extended the warranty on the pump on 2007 - 2009 models for 10 years or 120,000 miles.
RichAromaCoffeeCo
Sep 8, 2019 05:43 AM
michmike
Dec 4, 2014 12:06 PM
MiniLenny
Mar 20, 2009 10:56 PM
bahmoni
Aug 9, 2008 07:59 PM
