2013 Cooper S intermittent light failure - Mini Cooper Forums - Mini Cooper Enthusiast Forums
Thread Tools Search this Thread
Old 04-18-2017, 11:53 PM
Default 2013 Cooper S intermittent light failure
My rear tail light began losing its drivers side brake light every so often, becoming more frequent then finally quit. I tried replacing the bulb with no success. Now my drivers side rear signal light started showing the same symptoms and just quit for good today. Does anyone know what might be causing this issue? It seems weird that changing the bulb doesn't fix the issue.
Thank you in advance.
Thread Thread Starter Forum Replies Last Post
intermittent misfire 2008 MINI cabrio 179,000 ScottlandYard 05-up Mini Cooper/ Mini Cooper S Cabrio (R52) 0 08-12-2016 10:05 AM
Intermittent Misfire NotDFace 07-up MINI Cooper/Cooper S (R56) 0 04-11-2015 07:01 PM
engine light on in 2013 john cooper Liz Costello General Mini Cooper Talk 0 01-12-2014 01:55 PM
Intermittent misfire ShewbodMini General Tech 4 02-11-2011 06:11 AM
intermittent air conditioning lisalevi General Tech 0 03-28-2009 11:39 AM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
