Go Back   Mini Cooper Forums - Mini Cooper Enthusiast Forums > Mini Cooper Vehicles > 07-up MINI Cooper/Cooper S (R56)
Register Forgot Password?
Old 11-14-2011, 08:50 AM
Default Cannot Shift Out of Park
My 2007 will not let me shift from park. I'm assuming it is brake release solenoid as I was able to use the emergency release function once (and then the tab broke). So, I'm guessing I needed to replace this mechanism.
Has anyone else faced this issue? Any good references for a cheap, direct parts source?
Thanks!
Sponsored Links
Old 11-15-2011, 01:02 PM
Thanks!
I also had this problem. If you park on steep hills regularly and don't pull the parking brake up before you shift into park, the trans is difficult to shift out of park afterwards. I had it repaired at the dealer under warranty, so I'm not much help as to where else to buy the part. Once I got in the habit of using the parking brake every time I parked the car, I haven't had the issue since.
__________________
"When I die, I want to go peacefully in my sleep, like my grandfather did. Not screaming and yelling like the passengers in his car." Jack Handey
Tags
2007, 2011, cooper, gear, mechanism, mini, oout, park, parking, r56, release, shift, shifter, shifting, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
