need help with cel on 2008 S r56
Old 12-02-2014, 07:11 PM
hardiek's Avatar
Default need help with cel on 2008 S r56 (aka Batman)
A co-worker of mine is having problems with his 2008 Mini S and is unsure what to do. His check engine light went on just recently and found the following:
Check computer system with scanner, 9 errors stored. 2B32 – Throttle valve Actuator, 2B31 - Throttle valve Actuator, 287E – Intake Camshaft Timing, 2782 – Multiple Cylinder misfire, 277A – Cyl 4 Misfire, 2772 – Cyl misfire, 277E – Cyl 2 misfire, 2B64 – Intake Manifold pressure, unmetered air, 294A – intake cam position sensor faulty.
After further investigation there is also gas in the oil, visible cam wear, and it is idling rough.
Any ideas what the problem could be? Any help is appreciated.
Kevin
Old 12-05-2014, 11:32 PM
MiniCoop33's Avatar
First off you have gas in the oil so the engine is pretty much shot and you don't need to be running it right now. As soon as you can drain the oil and let it drain for a day or two just to be sure you got the gas out. You need to check all your hoses and your air box to find a leak that's what that sounds like. Other than that I'd need to look at it myself. Sorry best of luck
Old 12-10-2014, 02:14 PM
DasMini's Avatar
Fish eyes in the oil means motor rebuild I agree......best to take it to a skilled mechanic and have them take a look identify every issue and see what your bill is.....Sorry and good luck
kentuckynet
09-03-2021 02:13 AM
Mitsu
04-17-2015 09:21 PM
leennp
04-04-2015 10:50 AM
jamescooper
02-23-2012 08:39 PM
Kalinchuk
10-13-2010 09:29 PM
Quick Reply: need help with cel on 2008 S r56
