o2 sensor
o2 sensor
Hello i bought a mini cooper (2009 bmw mini one) not to long ago from japan and it just recently started having some problems. When i start the car the rpms go up and down and sometimes the car turns off and i would have to restart it.
I used my scanner and got the following codes P2414 & P2626 (Bank 1 sensor 1). From what i read that means the oxygen sensor before the cat (which i believe is the one under the hood?) has gone bad.
If someone would be so kind to help me frind the correct part so i can order it i would REALLY appreciate it because i have no idea where to look and i dont want to buy the wrong part.
2009 BMW Mini one
Engine code: N12B14A
Model code: ABA-ME14
2009 BMW Mini one
Can I have the last 7 digits of your vin? I just want to confirm the info below with it.
Pre-cat sensor - Mini Cooper - Emissions Equipment - Page 1
Public Service Alert:
Do NOT buy parts from ROCKAUTO. I ordered an O2 sensor for my 2010 Clubman S. They showed an exact fit, which was a Bosch 17112; 11-78-7-549860-00. The part arrived, and the box showed the above numbers - exactly what I wanted. I installed the part, but the check engine light came on within 30 miles. I finally discovered that the O2 sensor had totally different numbers on it - was made to fit a Peugeot of some kind. RockAuto is impossible to get hold of. (Probably by design). I finally replied to an email that I had received that confirmed my payment to RockAuto. They said I could use a Manufacturer's warranty to get the part replaced. But the dumb asses never recognized, or admitted, that they had sent the wrong part. I would have been more satisfied if I had just flushed the $113. down the toilet.
