04 Maintenance Schedule
Hi everybody! Im new here and would like to know where could I find the 04 Maintenance Schedule? Tried Edmunds, and searched with no results... don't want to ask the dealer as my hubby wants to take over maintenance from this point on.
The car has 40k miles.
Thanks!
rcp
Thanks!
rcp
RE: 04 Maintenance Schedule
It should go something like this:
Oil change - every 12-15K miles
Service 1 at 30-35K miles
Service 2 at50 - 55K miles
You know about the service indicator right? It tells you when you're due. If it's close to 0 I would say you're about due for your Service 2 but it's a high number 10,000 - 15,000 I think all you need to worry about are oil and filter changes, plugs at 100,000 miles etc, all the stuff you would on any car.
Hi AMG,
Need to change the oil, the indicator shows "-4700 service oil" (oil level is still good 80%full) what kind of brand of motor oil they recommend? Also where on line I can find oil&filters?
btw, Thanks so much for the attachment...
rcp
rcp
ORIGINAL: redchilipepper
Hi AMG,
rcp
Hi AMG,
rcp
We can confirm that -4700 means we missed it of 4700 miles, then we looked at the history and realized we had denied the service and then forgot of doing it. Dealer charges 125 to inspect and do oil+filter... we'll do that and then look at the work they think we should do... the only thing on there that sound hard to do is the auto-trasmission fluid change.
we'll see.
thanks so much
rcp
we'll see.
thanks so much
rcp
#9
You don't need to get the oil filter from a dealer. In fact, it's probably a bad idea because they so outrageously overcharge. WIX, Purolator, and I am sure, others, make these filters.
As to oil to use: use any good full synthetic oil: Some of the best are Amsoil, Redline, Royal Purple, or Motul' Mobil 1 or Castrol Syntec are a close second choice.
#10
u may b suprised to know that actually Jiffy Lube will sometimes carry the filters. I just go my 04 non S bout aweek ago and i started askin my boss about some of the maintainence stuff and he actually told me the some of the Jiffy Lubes in the Indianapolis area have the filters 4 the Mini, not 2 mention it would save u a boat load of cash!
Just so u know!
Alex
Just so u know!
Alex
