AC/Heater Blower Not Working
Old 09-15-2010, 04:47 PM
downwardkick's Avatar
Default AC/Heater Blower Not Working
Hi, I have a 2006 Mini-cooper and at one point I tried turning on my AC but no air comes out. I put it to either 1, 2, 3, or 4 to see if any air would come out but nothing. AC led button would not turn on either.
It seems that the blower stopped working for my AC/Heater. Even regular vent air would not work.
It had worked a couple of times where I left it on at level 4 and it suddenly started blowing cold air.
I checked the fuse that is located under the steering wheel and the fuse for the blower seems to be good. I even replaced it with the spare and it worked one time when I took the mini for a drive. But now it is dead again.
Any ideas on what to look for?
Your help is greatly appreciated. Thx.
Old 12-07-2016, 09:19 AM
pelet2's Avatar
Default 2006 mini cooper convertible i am having the same issue
? did you ever solve this issue?
Old 12-07-2016, 10:59 AM
Miguel Torres's Avatar
i also have the same issue
Old 01-10-2017, 07:51 AM
John Dean's Avatar
Did anyone get an answer to this. The mini garage is saying a replacement fan at around £400 including labour because they've got to take the dash out.
Old 01-12-2017, 10:57 AM
PelicanParts.com's Avatar
A replacement auxiliary fan? If you need cheaper parts we might have some here that work for you: PelicanParts.com - Mini Cooper & Cooper S (R50/R52/R53) - Ventilation & A/C. There are also a lot of DIY's out there that could help you do it yourself it you feel up to it.
Old 01-12-2017, 11:19 AM
John Dean's Avatar
Thanks for the link. The garage finally came back and accepted the fix under warranty - which is great because the DIY sounded a nightmare - dashboard out.
Kongfish
09-26-2013 09:31 PM
arahsay
04-19-2012 09:50 PM
sober_biker
04-09-2012 08:23 AM
perkman
09-06-2008 08:34 PM
1fstmini
05-26-2005 11:54 PM
Quick Reply: AC/Heater Blower Not Working
