Rattling from rear brakes
Old Feb 14, 2013 | 08:43 AM
minicooperman2012's Avatar
Default Rattling from rear brakes
Ever since I replaced the pads on the rear of my 2005, there has been a rattling sound. It sounds like a machine gun rattling at any speed, and is especially noticeable on the driver side. Any thoughts?
I've gone back and everything looks fine visually. The pad does have some play in the caliper, and I'm thinking that either the pad doesn't fit properly or the caliper has an issue.
Old Feb 20, 2013 | 11:34 AM
PelicanParts.com's Avatar
Who replaced the pads?
Old Feb 20, 2013 | 11:39 AM
I'd guess he's a DIYer
are the clips in good shape not bent ?
What brand pads did you use ?
how did you retract the cylinders ?
Old Feb 21, 2013 | 05:38 AM
I replaced the pads myself with pads purchased from Advance Auto...maybe their brand? They appeared to be a direct replacement, as I compared them to the old pads. I retracted the cylinders using a tool designed for these brakes. There appeared to be nothing bent or lose on the pads themselves.
The pads seem to be a bit loose in the caliper. The rattling ceases when the brakes are applied, and start right back to rattling as soon as the brakes are released.
marc0011
Aug 24, 2015 10:19 PM
HerMiniMan
Apr 4, 2014 10:39 AM
HerMiniMan
Apr 3, 2014 05:28 PM
dcsweet
Jun 29, 2012 11:24 AM
azam
Nov 18, 2008 10:32 AM
