Springs or Coilovers...HELP!
Old Apr 27, 2011 | 04:11 AM
JoJo's Avatar
Default Springs or Coilovers...HELP!
I have a 2002 Mini Cooper and have just changed the wheels so its now sitting on 17's.
Ideally I want to drop the car around 30/35mm to make it look a bit lower, I cant go any lower as i have to go over speed bumps in and out of work
My mini has the aero kit on it too so after reading various topics I can only assume if i go any lower the front may scrape which i do not want.
I have been looking at springs on ebay and various other places and think this is the cheapest and best option for what i want HOWEVER i have also read that there may be issues with the struts/dampers on the older generation mini (which i have-i think) so not really too sure what to do...
If i was to go with coilovers they come with all of that if i am correct? So wouldnt need to worry about replacing things etc?
Im really stuck..... Wat can everyone recomend?
Thanks! JoJo
Old Apr 27, 2011 | 03:53 PM
OK You want to lower your car , First off how do you drive it ....
Is the car a daily driver ?? or is it an all out show car??Is the car kitted??what are your local roads like??Snow and ice in the winter?? All of these will influence what type of lowering you might want ...
For a Daily driver I highly suggest a Drop spring , less maintenance/more reliable/Easier on the wallet
All out show car/kitted Think about coilovers or the Tiens for adjustability , ability to slam at shows
Bad local roads /big potholes/steep drives/roadkill galore think of a lesser drop or coilovers/tiens
Snow and ice in winter /think coilovers or tiens for ability to raise it back up for winter(will require alignment)
OK Now What do I need:
Lowering springs
Coilovers Struts:
Will I need Struts , YES any lowering will require struts... Can I use my stock struts?? Yes but they will blow and be worthless in no time...So WHY bother, I don't care if you are broke, save your money do it once and do it right !!!
KYB GR2's are very inexpensive CAN be used , But IMO they are not the RIGHT choice they are basically Upgraded stockers... Many have used them , but they fail pretty soon on Springs that are 2" or more, Same with coilovers
KYB AGX's Are more money/more adjustable hold up well to being lowered/ there are two part#'s one for 2" lower one for lower then 2" The lower set is better for coilover use as they have a shorter rod and prevent BOTTOMING...
Koni and Tokkiko both make excellent struts but are normally more expensive and harder to find...
Camber Kits:
After lowering will I need a Camber kit ??? YES you will definately need at least a REAR KIT,
Will I need a front kit ??? POSSIBLY I've dropped numerous cars for members/non members and here's what I have found, I've seen 1.3" springs require no kit to up to a 3 degree kit ... What I suggest is dropping the car/let springs settle for at least a week then take the car in for an alignment check, they can then get the car up on a rack and TELL you what kit you will need.... Do your homework on the alignment shop ask locals with local cars that are dropped where they got the alignments done... Try to use a shop thats used to lowered cars and able to get them up on the ramp...
OK how much will all this cost me ???
Plan on spending around $1000 on parts/alignment ... If you are not a do it yourselfer then add $300 for labor to install some shops will be more/less depending on your area.. Of course those prices are new parts , you might be able to get a deal on used parts but remember you can't be sure on used struts...
Jul 29, 2013 02:17 PM
Jun 25, 2013 11:17 AM
Jun 10, 2013 01:19 PM
impmonk
Mar 23, 2009 10:43 PM
Macbride
Feb 28, 2008 09:40 AM
