Reset counter for next Oil Change
Old Feb 5, 2009 | 10:46 AM
jon.hill@sbcglobal.net's Avatar
Default Reset counter for next Oil Change
Two things! First how does the dealer zero the computers counter since last oil change? Second, how do you change computer to read Fahrenheit from Celsius?
Old Feb 5, 2009 | 11:24 AM
To change that interval :turn the key to the second position and hold the odo reset button, tst will appear. keep holding until rst appears. press the reset again and it will reset the your service indicator
Be cautious as reseting may prevent them from "free" service if you are still covered
temp change is in the manual ... I forget of the top of my head
Old Feb 6, 2009 | 01:29 AM
JHawk's Avatar
For some reason it doesn't work for the 2002 mini. I did exactly what you said. I wonder if it's just different from year to year. Thanks anyway.
Old Feb 6, 2009 | 09:13 AM
Works fine on my 05 . ... figured all were the same ...
Also try holding the odo down then turning the key on ....
theateist
Jun 24, 2015 11:54 AM
cmoskat
Aug 26, 2009 07:48 PM
pcowle
Mar 14, 2009 01:49 PM
lawddf
6
Feb 14, 2009 03:41 PM
aussieinaz
Nov 16, 2007 12:43 AM
