Need help on 2006 Cooper S
Old 06-22-2014, 09:49 PM
Vu Tran's Avatar
Default Need help on 2006 Cooper S
I need help on figuring out why my cooper is hesitating on acceleration. Is anyone having this type of problem? If so, all help is appreciated. Once passed a certain RPM, it is fine. Thanks!
Old 06-22-2014, 11:50 PM
teamslam1's Avatar
Could be the throttle body or just carbon build up or even clogged injectors. Won't know until you start tearing thru your engine.
Old 07-15-2014, 08:27 AM
Platinum Sponsor
+1 on checking the throttle body. Have you thrown a check engine light code ?
Throttle body might need cleaned or it might be failing.
For The Cooper S gen 1 :
Throttle Housing / Body part # 13541503358
http://www.ecstuning.com/Search/SiteSearch/13541503358/
The butterfly valve should be clean like this , when gunk build up it sticks on the first throttle and releases.
If its bad / needs replaced. It throws a throttle code.
MINIPEARLDC
10-16-2014 12:08 AM
lakeober
06-18-2013 05:55 PM
Yardley
11-26-2012 08:18 AM
Lhall3489
04-20-2012 10:58 PM
Kalinchuk
10-13-2010 09:29 PM
Quick Reply: Need help on 2006 Cooper S
