Go Back   Mini Cooper Forums - Mini Cooper Enthusiast Forums > Mini Cooper Vehicles > 2002-2006 Mini Cooper S (R53)
Register Forgot Password?
Old 05-08-2011, 07:28 PM
Question 05 Mini S problems.
So recently, my 2005 mini s (manual) has been just cutting off randomly when in neutral. Also when I cut my car off, my fan keeps running for a few minutes. And then today I was just driving and my engine temperature gauge went all the way up and then went right back down to normal. There are just a lot of weird things happening and I was wondering if anyone has any ideas on what could be happening to it. Thanks!
Sponsored Links
Old 05-11-2011, 08:17 PM
Your fan Running issue could be a problem with low coolant chk coolant level when cold. they have a very common coolant leak @ plastic thermostat housing to cylinder head they leak coolant (very common)
Good luck
Old 05-18-2011, 09:32 PM
The temp gauge showing getting hot then going cooler quickly could be the sign of a sticcky thermostat. An easy fix, but not sure how easy on a mini.
Tags
cold, common, coolant, cooper, engine, forum, gauge, hot, low, mini, problem, problems, runs, stuck, temp
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
