Rattling Dashboard! Help!
Old Jul 28, 2008 | 02:53 PM
azam's Avatar
Default Rattling Dashboard! Help!
Hi guys,
I have some rattling coming from my dash near the sensor in the center of the upper dash. The dealership wants to charge me $400 just to put it back into place. Any work arounds or advice? Thanks in advance!
Old Aug 26, 2008 | 11:07 AM
yuille36's Avatar
Member
Default RE: Rattling Dashboard! Help!
I have that same problem in my 03 Cooper S, if you figure something out please let me know.
Old Oct 4, 2008 | 03:08 PM
ymperformance's Avatar
use two wiper inserts and cut to desired length, place in front of the dash where it meets the windoow and that will hold the centering pin on the underside of the dash in place.
Old Oct 17, 2008 | 10:12 AM
jab91977's Avatar
This was a problem I had fixed a couple of years ago (at the dealer). I remember the dealer telling me the real fix ment taking out the dash. The thing thats rattling is a dash board guide pin inside it's housing. It sounds like it's the senser but it's not. The good news is other than the labor time it takes there's no parts to buy, you just wrap the pin with felt or something similar and reinstall. I haven't had a problem since they fixed it.
Old Nov 14, 2008 | 10:30 AM
podies's Avatar
I have an 05 mini s andI found the problem was the glove compartment door was making the noise. I took the door off and then remounted it and the problem went away.
Old Nov 18, 2008 | 10:32 AM
Soopercooperinfo's Avatar
Check out two remediesfound on www.soopercooperinfo.com. It may help.
aschafe
Apr 25, 2016 02:07 PM
minicooperman2012
Feb 21, 2013 05:38 AM
aschafe
Jul 4, 2012 08:57 AM
cooperscooper32
Jun 29, 2012 07:00 PM
Have66&05
Mar 10, 2012 12:20 AM
