Power Steering - GONE!
Old Nov 17, 2008 | 11:33 AM
gt4play's Avatar
Default Power Steering - GONE!
Hi Folks,
I'm relatively new to the Mini scene and haven't really had to do much work on the used 05 Cooper S I bought a few months back. But it appears (from my reading) the power steering pump has given up the ghost.
I haven't gone through any troubleshooting, but is it possible this could just be a fuse issue? Or is it more likely (as this appears to be common) that the pump just simply died?
Also, how do I go about sourcing one? Sure, I can go through the local dealership and pay the $670 or so price. Obviously it comes at a ridiculous markup as I can find these all over the web for around $460. But odd thing is (and I never encountered this with all the Toyotas I have ever worked on) I can't get the parts department to give me a P/N. Is this standard procedure? So basically, are these pumps relatively generic or do I really need to find one that's going to be specific to a "2005" mini S?
Thanks much ahead of time for any feedback! It's a bear driving this car without power steering...
-Chris
Old Nov 17, 2008 | 03:07 PM
Default RE: Power Steering - GONE!
Check the WIRING harness feeding the pump ... I've seen several that the harness pins were so corroded they wont pass current ...
Old Nov 17, 2008 | 03:51 PM
gt4play's Avatar
Okay, I'll have a look at that first. Curious (just so I know what I'm getting into ahead of time) does the pump need to be dropped in order to get a good look at the electrical connects?
Thank for the feedback!
-Chris
Old Nov 17, 2008 | 04:36 PM
yuille36's Avatar
Member
I know you already check this, but it is possible that you might have not checked the fluid level in the reservoir for power steering fluid.
Old Nov 17, 2008 | 04:54 PM
yuille36's Avatar
Member
If you indeed need a new pump, then this company can rebuild the pump for allot cheaper
[/align]
[/align]BBA Remanufacturing, Inc.
300 Myles Standish Blvd.
Taunton, MA 02780
Toll Free: (866) 573-2740
This company will repair the pump for $200......with a warranty for as long as you own the car!
[/align]They have a 3 day max turn around on the rebuild.
Old Nov 17, 2008 | 10:02 PM
gt4play's Avatar
Yep, fluid level is fine.
Also, having given it some thought about the wiring...I would have assumed that (if it was a corroded connection) that I would have noticed some intermittent problems before hand (i.e. loss of power during a hard corner or bumpy road conditions). But it was running perfectly...just all of the sudden...nothing.
Old Nov 17, 2008 | 10:03 PM
gt4play's Avatar
Thanks for the information. I'll be giving them a call tomorrow.
-C
Dec 26, 2013 01:48 PM
Aug 19, 2013 01:11 PM
orsmo
Mar 1, 2013 02:50 PM
chester
Jul 14, 2011 05:00 PM
what?!
Aug 25, 2007 01:48 AM
