Help! Suspension is rough
I'm in desperate need of some diagnosis of my suspension. I just bought a 2004 Cooper S and it appears that it may have been lowered, but I'm not sure. I just looked and the rear shocks have Mini stamped on them, but it seems to sit very close to the rear wheels and the ride on rough roads is very very bumpy. Is there a best way to determine if the springs have been changed? Thanks in advance for any help!
It could be that they're just on their last legs or that your OE springs are sagging. Can you tell if the front or rear shocks/struts are leaking? Typically, aftermarket springs will be a different color. What color are they?
Springs might be stock. I'd have all struts/shocks inspected. You should here clunking noises when suspension has gone bad. Do you hear any noise from the rear? Is it lower in the rear than it is in the front? How many miles are on your R53? Springs will sag and become inefficient over time, but they do last much longer than struts/shocks.
LadyV
02-18-2016 01:30 PM
