MCS is creaking when starting from a stop
Old 07-20-2014, 10:30 PM
ellysa's Avatar
Default MCS is creaking when starting from a stop
It only happens during the first 10-15 minutes of driving and it only does it when I'm starting from a stop and it isn't every time I start, maybe every couple starts. (It used to only do it when I was starting on a hill). It literally sounds like a creaking door that needs to be greased or something. Is this anything I need to worry about?
Thanks in advance
Old 07-24-2014, 07:16 AM
Platinum Sponsor
Sounds like rear suspension component. Upper rear strut mounts. One set for each side.
#10 rear shock mount foam bushing.
#10 Shock Mount - Rear 33526754123
http://www.ecstuning.com/Search/SiteSearch/33526754123/ES1981541/
These can make noises when worn and compressed over time.
Until its warms up. Check you rear brake calipers, pads etc , and if the emergency brake cables are fine. If your emergency brake cables are rusted it drags on the rear brakes, pads against rotors.
Emergency brake cables refresh kit. Part # 34406777400KT
http://www.ecstuning.com/Search/SiteSearch/34406777400KT/
Old 07-25-2014, 05:14 AM
ellysa's Avatar
My E-brake has been acting funny lately, usually you have the 4 or 5 clicks, on a flat surface i'll go to either click 2 or 3, never on 4/5 unless I'm on a steep hill (which is rare), sometimes it won't click until it gets to the 4th level, or i'll put the e brake on click 2 on a flat surface and it won't even engage, ill still roll... It freaks me out. Is it normal for the e brake to mess up sometimes?
prblmslvd
02-28-2013 05:16 PM
06-25-2012 11:23 AM
Marso99
08-05-2011 10:25 PM
Bob 2009 rag top S manual
10-30-2010 06:19 AM
JBRadMini
09-14-2008 04:08 PM
Quick Reply: MCS is creaking when starting from a stop
