#51
M7 Speed available @ ECS Tuning
One of the most trusted sources for aftermarket and performance MINI parts is available through ECS Tuning. Get anything from intakes to supercharger pulleys, end-links to suspension reinforcement parts, plus way more.
M7 will get you the performance and power that you want out your MINI and get you out tearing up the canyons in not time!
Click HERE for M7 Speed R50 R52 R53 2002-2008 MINI Cooper/S/JCW (Gen 1)
Click HERE for M7 Speed R56-R59 2007+ MINI Cooper/S/JCW (Gen2)
Click HERE for M7 Speed MINI Countryman / MINI Paceman (Gen 2)
#52
Forge Indcution Kit | F54-F57 MINI Cooper /S/JCW
ECS now supplies one of the top Performance Intake Systems available for your F56+ MINI Cooper.
This intake with a Pipercross performance foam filter has been proven to increase air intake volume while enhancing the induction sound of your engine.
More air available means more potential power. It's for this simple reason that an easy-to-install performance intake from ECS should be first on your list of engine upgrades for your MINI.
Up to 10bhp gain
More Air. More Power.
Fitment:
F55 MINI Cooper /S/JCW '15+
F56 MINI Cooper /S/JCW '14+
F57 MINI Cooper Convertible /S/JCW '16+
F54 MINI Clubman /S/JCW '16+
Click HERE For MINI Cooper Options
Helix/Depo Headlight Options For R55-R59
ECS now offers Helix/Depo Blackout and Chrome Halogen Projector Headlights for your MINI R55-R59, designed to look like the MINI OEM HID Projector headlights.
Sets are available for cars equipped with factory Halogen headlights.
These Helix/Depo brand headlights feature high impact plastic lenses with a black or chrome housing which include motorized leveling. DOT & SAE compliant.
Halogen Headlights contain H7 Projector bulbs and Halogen PY21 turn signal bulbs which are included. Or upgrade to Ziza H7 premium bulbs listed below.
Cleaner Looks, Better Style
Fits:
R56 MINI Cooper /S/JCW 2007-2013
R55 MINI Clubman /S/JCW 2008-2015
R57 MINI Cooper Convertible /S/JCW 2009-2015
R58 MINI Coupe' /S/JCW 2012-2015
R59 MINI Roadster /S/JCW 2012-2015
*Halogen projector for Halogen headlights
Air Lift Performance Suspension | MINI R50-R53
This Air Lift Air Ride kit offers one touch ride height preset option. No more wrenches. No more tedious adjustments. This digital management kit puts all system controls inside the car, so you can make fast ride height adjustments while staying clean.
Great for performance, dial in your ride with adjustable front and rear shocks.
Go low for show; add lift for general driving or to clear obstructions. Laugh at speed bumps and dangerous driveway entrances.
The MINI Gen1 R50/R52/R53 Air Lift kit allows for up to 5.1 inches of lowering!
Get Low with Airlift Performance
Fits:
R50-R53 MINI Cooper/S/JCW 2002-2008
Air Lift Performance Suspension | MINI R55-R58
No other suspension gives you the ability to comfortably drive you car daily, slam it to the ground for a show-winning stance, or tear up your favorite race track - all with the touch of a button.
Make no mistake - these are thoroughly performance-oriented kits. Handling dynamics are not compromised - simply dial in your ride to adjust the front and rear shocks.
Select your front and rear air ride kits then choose between 3H, 3P, V2, or Manual Paddle Valves Air Management Systems to complete the full system.
The MINI Gen 2 R56+ Air Lift kit allows for up to 4.1 inches of a drop.
Fits:
R55-R59 MINI Cooper/S/JCW 2007-2016
Up to 10bhp gain
Fitment:
Fits:
Fits:
Fits:
#53
ECS Essentials For Your Gen 1 MINI
It all starts with the essentials - Do it right, or do it twice.
ECS Essentials are a special blend of drivetrain and styling upgrades designed to fine tune and enhance the performance of your MINI.
The ECS Tow Hook/Plate Mount kit lets you use a front plate without the need of drilling into the bumper to mount the front plate. Improve pedal feel with Exact-Fit Stainless Steel Lines and enhance overall wheel appearance by upgrading to an ECS wheel bolts.
Build it better, build it stronger, build it with ECS.
Performance in Mind
Fits:
R50 MINI Cooper 2002-2006
R53 MINI Cooper S/JCW 2002-2006
R52 MINI Cooper Convertible /S/JCW 2005-2008
ECS Essentials For Your Gen 2 MINI
The ECS Tow Hook/Plate Mount kit lets you use a front plate without the need of drilling into the bumper to mount the front plate. Improve pedal feel with Exact-Fit Stainless Steel Lines and enhance overall wheel appearance by upgrading to ECS wheel bolts.
Fits:
R55 MINI Clubman /S/JCW (2008-2015)
R56 MINI Cooper /S/JCW (2007-2013)
R57 MINI Cooper Convertible /S/JCW (2009-2015)
R58 MINI Coupe' /S/JCW (2012-2015)
R59 MINI Roadster /S/JCW (2012-2015)
ECS Essentials For Your Gen 3 MINI
The ECS Wheel Spacer Kitt lets you push the wheels out for a more flush fit or for the wheels to clear a big brake kit. Improve the stock brake rotor screws that rust and tend to stick making the next time you change the brakes/rotors a complicated job.
Fitment:
F54 MINI Clubaman /All4/S/S ALL4/JCW 2016+
F55 MINI Cooper /S/JCW 2015+
F56 MINI Cooper /S/JCW 2014+
F57 MINI Cooper Convertible /S/JCW 2016+
Assembled By ECS Kits For Your Gen 1 MINI
These are all-in-one kits that take the guesswork out of what you really need to keep your MINI performing at its best. From full Cooling System Refreshes, Oil Service Kits, to Automatic Transmission Services kits.
Specifically put together by ECS Tuning specialists, Assembled by ECS kits give you the piece of mind that the job is complete.
Convenience
Fits:
Assembled By ECS For Your Gen 2 MINI
Convenience
Fits:
R56 MINI Cooper S/JCW (2007-2013)
R55 MINI Clubman S/JCW (2008-2015)
R57 MINI Cooper Convertible S/JCW (2009-2015)
R58 MINI Coupe' S/JCW (2012-2015)
R59 MINI Roadster S/JCW (2012-2015)
Performance in Mind
Fits:
Fits:
Fitment:
Convenience
Fits:
Convenience
Fits:
#54
GruppeM Japan AIR SYSTEMS
GruppeM RAM AIR SYSTEMS epitomize the GruppeM philosophy of attention to detail. By replacing the factory air handling systems, increased airflow streams into the combustion chamber. GruppeM completes this by utilizing unique designs in order to optimize air flow for enhanced performance. One feature that truly sets GruppeM apart, is that they design their intakes to use fresh air instead of the hot engine bay heat. As a further benefit, they enhance the sound too!
The carbon duct of an exclusive design develops the shape which does full interception of the heat in an engine room. Fresh air is imported direct it falls and inhalation air temperature is stabilized.Torque and an upgrade are realized all over the districts from low revolution to a high revolution region.You can also enjoy a sporty air intake sound.
Select Your MINI from the drop down.
Fits:
R50 R52 R53, R56-R59 S/JCW Coverage.
Spyder Projector Blackout Headlights | MINI R60/R61
ECS now offers Spyder Blackout and Chrome Halogen Projector Headlights for your MINI Countryman/Paceman, designed to look like the MINI F60+ OEM HID Projector headlights.
These Spyder brand headlights feature high impact plastic lenses with a black housing which include adjustable leveling. DOT & SAE compliant.
Halogen Headlights contain H9 Projector bulbs and Halogen PY21 turn signal bulbs which are included. Looks great to match with Ziza LED Position lights.
Fits:
R60 MINI Countryman /S/SX(All4)/JCW 2011+
R61 MINI Paceman /S/SX(All4)/JCW 2013+
Fits:
Fits:
#55
Oil Service Kits 10% Off | MINI
While changing your own oil gives you the confidence of knowing your vehicle and how to address its basic needs, using inappropriate parts and fluids will soon prove to be counterproductive and damaging.
The wisest and most thorough approach is to invest in a complete Oil Service Kit.
ECS-assembled and genuine MINI Oil Service Kits have been scrutinized by our in-house engineers so you can back up that confidence of having done the job on your own.
Change and Save
Fits:
Oil Service Kits 10% Off | MINI Gen2
Change and Save
Fits:
R60 MINI Countryman /S/SX(ALL4)/JCW (2011+)
R61 MINI Paceman /S/SX(ALL4)/JCW (2013+)
For Gen 3 MINIs 2014+ click here :
1.5L Cooper
https://www.ecstuning.com/Mini-2014-Cooper-F56-Base-3_Door-B38A15A/Engine/Oil_Service/
2.0L Cooper S / JCW
https://www.ecstuning.com/Mini-2014-Cooper-F56-S-3_Door-B48A20A/Engine/Oil_Service/
Change and Save
Fits:
Change and Save
Fits:
1.5L Cooper
2.0L Cooper S / JCW
#56
BMC Air Filter Now @ ECS
BMC air filters are produced using a "Full Molding" system that enables the characteristic red filter to be realized from a single mold with no welded joints thus avoiding easy breakage. The rubber used in BMC air filtering systems has a long life, is very durable and has optimum adhesion characteristics to all shapes of airboxes.
BMC filters are made of a multi-layered cotton gauze soaked with low viscosity oil covered with an epoxy coated alloy mesh to ensure protection from petrol fumes and oxidization due to air humidity.
All BMC air filters are pre-oiled, and they can be washed and regenerated by using the appropriate BMC regeneration kit.
**Original equipment for MINI Cooper JCW Sounds kit in your Gen 1 MINI!!**
#57
Assembled By ECS For Your Gen 1 MINI
Change and Save
Fits:
Fitment:
Assembled By ECS For Your Gen 2 MINI Countryman / Paceman
On sale for a limited time
Fits: ( Cooper S & All4 only)
R60 MINI Countryman S/SX(ALL4) (2011+)
R61 MINI Paceman S/SX(ALL4) (2013+)
Assembled By ECS For Your Gen 3 MINI
These are all-in-one kits that take the guesswork out of what you really need to keep your MINI performing at its best. From full Brake Fluid Flush Kits, Oil Service Kits, to a Vinyl Wrap Install Kit.
Specifically put together by ECS Tuning specialists, Assembled by ECS kits give you the peace of mind that the job is complete.
Fits:
F55 MINI Cooper S 2015+
F56 MINI Cooper S/JCW 2014+
F57 MINI Cooper Convertible S/JCW 2016+
F54 MINI Clubman S/ All4/JCW 2016+
Change and Save
Fits:
Fitment:
Fits:
#58
Powerflex For Your Gen 1 MINI
Sharpened handling. Increased agility. Tactile responsiveness. A feeling of being one with car and road. Replacing stock bushings with Powerflex polyurethane components will deliver all that and more.
ECS is proud to carry the Powerflex brand of performance bushings. Powerflex is a world-renowned name in high-performance products, and they manufacture an array of quality suspension and chassis components.
From subframe mounts to control arm and sway bar bushings and more, nothing overpowers the Powerflex catalog and their reputation for durability and quality.
Fits:
R50/R52/R53 MINI Cooper /S/JCW '02-'08
Click HERE For Gen 1 MINI Cooper Options
Powerflex Polyurethane Bushings For Your Gen 2 MINI
Fitment:
Click HERE For Gen 2 MINI Cooper Options
Powerflex Polyurethane Bushings For Your Gen 3 MINI
Fits:
F54-F57 MINI Cooper /S/JCW 2014+
Click HERE For Gen 3 MINI Cooper Options
Fits:
Fitment:
Fits:
#59
Ziza LED Kits For Your Gen 3 MINI
Make night time, the right time. Let your MINI look great after hours with new LED lighting upgrades from Ziza.
Light a little; light a lot. Choose individual zone lighting changes at glove box, trunk, or reverse lights. Or grab all three to complete the interior/exterior rear lighting package and banish dirty yellow light from your MINI, once and for all.
These LEDs are as easy to install as standard bulbs. Their improved illumination and upscale look will be a welcome addition to any interior/exterior.
Fits:
F55 MINI Cooper /S 2015+
Click HERE For MINI Cooper Ziza Options
AAE Power Steering Pumps R50 R52 R53 MINI
The MINI power steering pump and power line repair kit was made to repair both the return and suction line that are located between the power steering pump and reservoir. This repairs the common power steering loss and failure due to a failed pump or leaking lines.
Choose from three levels of power steering pump repair kits, from just the replacement pump to the complete power steering system overhaul.
Each pump is re-manufactured here in the USA using ZF parts, the reliable OEM manufacturer.
Get your power steering back.
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper / S / JCW ( 2005-2008 )
R53 MINI Cooper S / JCW ( 2002-2006 )
Fits:
Fits:
#60
K-MAC For Your MINI Cooper
Factory stock suspensions bring increased tire wear and more frequent tire replacement, as a “full alignment” consists only of rudimentary toe-angle adjustment.
For over forty years, K-MAC has been hard at work developing a solution to this problem with patented innovations in camber/caster plates and bushing kits, allowing easy adjustment for a true “full four-wheel alignment” to be performed by any competent shop or individual.
KMAC gives you the ability to have your suspension properly dialed in for your use.
Fits:
R56 MINI Cooper /S/JCW'07+
R55 MINI Clubman /S/JCW '08+
R57 MINI Cooper Convertible /S/JCW '09+
R58 MINI Coupe' /S/JCW '12+
R59 MINI Roadster /S/JCW '12+
Click HERE For MINI Cooper Gen 2 Options
Gen 1 MINI Cooper
Fits:
R50-R53 MINI Cooper/S/JCW (2002-2008)
Click HERE For MINI Cooper Gen 1 Options
Gen 2 MINI Countryman / MINI Paceman
Fits:
Click HERE For MINI Cooper Gen 2 MINI Countryman/ Paceman Options
Alzor Wheels For Your Gen 3 F56 MINI Cooper
These new sets of Alzor Style wheels will not only change the look of your vehicle, but also capture the attention of others. The multi-classic to modern styles wheels will give your car a sleek appearance that will keep people looking as you pass.
Designed to bolt right up to your car, these wheels fit without any hassle.
If you want to achieve an extreme look, don't forget to check out our large assortment of ECS Tuning wheel spacers and lug bolts.
Stylize your MINI
Fits:
F56 MINI Cooper /S '14+
Fits:
Gen 1 MINI Cooper
Fits:
Fits:
Stylize your MINI
Fits:
