Clutch adjustment?
Clutch adjustment?
My friend has a 2006 S with 6 speed manual. The car drives good and has 70k on it. The clutch does not slip but catches at the end of the pedal, so I would say around 25% of tip of pedal. Do these have adjustments until it wears off or is it usually time to change them? Any idea where can he gets parts inexpensive? He is going to sell it after he installs the clutch if needed, does the flywheel needs changing as well? or just the clutch and throw out bearing? Thanks
Unfortunately, I don't believe there is a way to adjust the clutch. Check out our MINI catalog for parts: Pelican Parts - MINI Parts & Accessories Catalog
-Jorge
-Jorge
05-07-2015 12:20 PM
05-03-2013 11:32 AM
