Go Back   Mini Cooper Forums - Mini Cooper Enthusiast Forums > General Mini Cooper Forums > General Tech
Register Forgot Password?
Search
Old 12-04-2009, 07:02 AM
Default No heat - how to bleed cooling system?
My '04 Mini (non-S) has no heat. It has NAV, thus no temp gauge, so I have no idea how hot the car is running, but I do know the radiator fan comes on during extended idle, so I'm guessing the t-stat is not stuck open.
First the coolant was low (in the expansion tank) so I filled the radiator and tank and was squeezing the upper radiator elbow hose to feel for flow when it sprung a leak in my hand. Seems it had been wearing on a corner of the alternator. I then replaced it (at a ridiculous dealer cost of $45) and filled up again. I'm guessing it got some air in the system when I topped off the radiator, if it didn’t already have some in it. I have tried bleeding the system with the two bleeder screws (one just behind the elbow hose I replaced and one under and left of the battery on the hoses to the heater core), but have not been able to get the heat back. Fluid always come out, but it accompanied by bubbling – not sure if that is normal. Someone told me I should drop the lower radiator hose, drain all the coolant and start over with a re-fill. So what is the proper procedure for getting air out of the system? Is there a sequence for bleeding? engine off/on? heat off/on? I don’t want to drive it and blow the head gasket!
__________________
'04 MINI R50 70k
'95 BMW 318iC 200k
Sponsored Links
Old 12-26-2009, 02:50 AM
Send a message via ICQ to Symbogs09
Default No heat how to bleed cooling system
Ok.
Changed thermostat and flushed heater core. Still no heat while the car isnt moving. Anyone have any ideas?
Old 12-26-2009, 05:52 PM
Changed the radiator cap ???
Old 05-29-2012, 01:32 PM
PelicanParts.com's Avatar
For help on flushing your MINI's coolant:Pelican Technical Article: MINI Cooper - Coolant Change
-Jorge
__________________
Pelican Parts Inc
View our MINI Catalog
LIKE us on Facebook
Your One-Stop Shop for the DIY Mechanic!
1600 240th Street, Harbor City, CA 90710 T: 888.280.7799
Tags
2006, bleed, bleeding, coolant, cooling, cooper, fill, heat, heating, low, mini, procedure, proper, radiator, system
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
