Go Back   Mini Cooper Forums - Mini Cooper Enthusiast Forums > General Mini Cooper Forums > General Tech
Register Forgot Password?
Old 01-24-2011, 12:49 AM
Dee Dee is offline
Default Run Flat Warning Light
Hi
Every time I drive my mini cooper (2002) the 'run flat tyre' warning light comes on and flashes (which according to the hand book mean I have a puncture). However I do not have run flat tyres on my mini......??? And I do not have a puncture. So I am wondering what does this mean and/or how do I stop it from flashing
Thanks Dee
Sponsored Links
Old 01-24-2011, 07:43 AM
First check each tires tire pressure and be sure they are at the suggested pressure, even a few PSI can get the light on.
Next you need to reset the light. Follow the manual instructions
If this doesn't cure it the TPMS sensor in the wheel is bad you will need either the dealer or a tire shop diagnose which one went out
Old 01-24-2011, 06:00 PM
Dee Dee is offline
Thanks for your quick reply
I will give those suggestions ago today, and see how they work.
Old 01-27-2011, 08:41 AM
The light has to do with tire pressure monitoring systems. (tpms)
It lets you know if your your tires are not at the required pressure or if one is lower than the others depending on the type of system. In cars with out run flats you can do a visual and a touch inspection to know if you have a flat. If you do not have a visual and when you get to a gas station then check the PSI and add air.
Tags
02, 2002, cooper, flashing, flat, lighs, light, mini, pressure, run, runflats, tire, tires, tpms, tyre, warning
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
