Starter/Anti theft ?
Old 10-31-2009, 07:46 PM
coops's Avatar
Default Starter/Anti theft ?
Well I saved the ignition barrel, foreign piece of plastic was stopping the key from entering. I have all the Ignition lights, everything works, fitted a new battery as well, the non remote key will open and lock all the doors ok,But nothing when your turn the key to engage the starter.Does the imobilser initiate with the central locking or is the key coded to the ignition barrel ? Has anyone had similar problem and answers? Cheers Coops
Old 11-01-2009, 08:23 AM
There is no "factory immobilizer" There is an optional alarm system , but have no idea if you have one installed ...
If I remember correctly yours was a "theft recovery" they might have tried to hotwire it and blew fuses/cut wires ect ... I'd check for these items first ...
Also unsure how long the cars sat it might have lost computer programming as well
Old 11-03-2009, 06:46 PM
coops's Avatar
If it has lost computer program how can i reset. Do you know if the chip in the key matches with any other chip in the vehicle somewhere ie the computer,central locking etc or what does it do.
Old 11-03-2009, 09:17 PM
computer programming is dealer only ...
I forget what year you have , the early ones have no chip in the key the round hockey puck ones do have a code
Old 11-04-2009, 05:32 AM
coops's Avatar
it is an R50 12/2003. It definatley has a chip in the key i had a look and apparently it interfaces with the antennae ring around the ignition barrel which tells the computer to allow it to start. So I need to speak to someone on how to test the ring or the computer. the nearest dealer is 900km away.
Old 12-02-2009, 12:25 AM
Pexyreep73's Avatar
Im pretty sure the new starter is ok. The old starter was doing the same thing so that is the only reason I put the new one in. There is also a noise comming from the area around the firewall. I just cant pinpoint the precise area.
Old 12-02-2009, 04:03 AM
bettyv's Avatar
Arseny Libon
08-12-2013 12:34 AM
08-06-2013 12:06 PM
TommyL
02-13-2011 05:10 PM
lolo1964
04-14-2010 01:29 AM
cjackson
11-26-2008 10:35 AM
Quick Reply: Starter/Anti theft ?
