remove 4 lug bolts, wheel comes off, right?
Old Nov 30, 2009 | 10:03 AM
04minis's Avatar
Default remove 4 lug bolts, wheel comes off, right?
Hi everyone,
I just got a used 04 cooper S, and since I live in Canada, I need to put snow tires on. I jack up the car, remove the 4 lug bolts, and the wheel is still firmly mounted to the car. I've tried everything short of taking a sledgehammer to it. Is there some bizarre German apparatus holding the wheel there, that I can't see?
Old Nov 30, 2009 | 07:15 PM
likely rust is firmly attaching it ... hard impact at the top/bottom to loosen , when you remount clean the inner hub and the wheel with a wire brush and apply a light coat of never seize to prevent it from happening again,,,
Old Dec 1, 2009 | 06:18 PM
04minis's Avatar
Thanks bad venge. I took it to my friendly neighbourhood garage, and he used a big pipe to pry them off. Whoever installed the wheels prior obviously didn't grease up the hub. Good thing I didn't discover this at the side of the road with a flat.
May 6, 2014 03:40 PM
Apr 28, 2014 09:27 AM
sneedspeed
Jul 18, 2013 07:49 AM
RandomWarrior
May 24, 2012 06:41 PM
sneedspeed
Feb 29, 2012 01:18 PM
