MiniCooper Forums - Photo Galleries - Create an Account
Go Back   Mini Cooper Forums - Mini Cooper Enthusiast Forums > General Mini Cooper Forums > MCF Help & Suggestion Center
Register Forgot Password?
Old 11-30-2009, 11:03 AM
Default remove 4 lug bolts, wheel comes off, right?
Hi everyone,
I just got a used 04 cooper S, and since I live in Canada, I need to put snow tires on. I jack up the car, remove the 4 lug bolts, and the wheel is still firmly mounted to the car. I've tried everything short of taking a sledgehammer to it. Is there some bizarre German apparatus holding the wheel there, that I can't see?
Sponsored Links
Old 11-30-2009, 08:15 PM
likely rust is firmly attaching it ... hard impact at the top/bottom to loosen , when you remount clean the inner hub and the wheel with a wire brush and apply a light coat of never seize to prevent it from happening again,,,
Old 12-01-2009, 07:18 PM
Thanks bad venge. I took it to my friendly neighbourhood garage, and he used a big pipe to pry them off. Whoever installed the wheels prior obviously didn't grease up the hub. Good thing I didn't discover this at the side of the road with a flat.
Tags
2006, 2008, bolt, bolts, cooper, jacking, lug, mini, removal, remove, removing, rust, size, wheel, wheels
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
