Upgraded mini cooper s r56
Hey guys, I have a 2009 mini cooper s and I've installed the hot side boost tube running from the turbo down to the inter cooler and also the Aem cold air induction intake kit. Runs great and sounds great and really makes a bit of difference. My one concern is sometimes when I'm getting up on it, the car will almost kinda jerk... Idk what this could be... I got a new timing chain back at 80,000 miles and it's only got 101000 now so I don't think it's that... Could this be back pressure? My friend said because I'm pulling in so much more air, now I can't get it out quick enough and it's building up... He recommended an exhaust upgrade... I wanted some more opinions from you guys, thanks!
I'd highly recommend calling a MINI performance shop and seeing what they might recommend as far as what your friend said.
I'm curious about a few things. If/when have you ever done a carbon clean up? How many miles are on your MINI? When was the last time routine items were replaced, i.e. spark plugs, etc?
Here is what the build up on the valves will look like:
