Intermittent trouble lights – 2006 R52 S 6 speed manual
Old Aug 17, 2022 | 09:40 AM
jerryp's Avatar
Default Intermittent trouble lights – 2006 R52 S 6 speed manual
Here’s the problem, sometimes when I drive a short distance the tire light and the DSC light will come on. Everything drives fine except for the lights and the most annoying thing is that sometimes the cruise control won’t stay on.
On a very rare occasion the temp gauge would go completely nuts. I recently replaced the thermostat and the cooling water reservoir to fix that.
So what I do to handle the trouble light problems is to turn the car off and back on again. Sometime this doesn’t handle it and other times it stays good for hundreds of miles of driving. Then it might randomly come back. Lately it came back and restarting it isn’t clearing it.
I'll clear all the trouble codes and it will be good for a short time but it's annoying.
I suspect it’s dirt, water or corrosion in some wiring harness connector BUT I don’t know where these are.
I was just hoping someone could tell me where to look.
Simple as that unless there is some other recommended fix.
Thanks.
BrendaCooper
Jan 21, 2022 03:57 PM
PCM1999
Aug 27, 2020 10:41 PM
ewward31
Nov 20, 2017 12:39 AM
darlhohn
Mar 11, 2012 04:26 PM
Coco Bean
May 7, 2011 07:49 PM
