Blown gasket, cost of engine replacement?
Old 07-24-2011, 01:39 PM
mlg321's Avatar
Default Blown gasket, cost of engine replacement?
I have a 2006 Mini Cooper S Cabrio and the engine overheated apparently and the head gasket is blown. They are quoting me $5-6k to fix it. The break down is this:
-Remove and replace gasoline, replace fuel pump and fuel filter $655.00 + cost of fuel.
-Remove and replace Injectors, Fuel rail and pressure regulator due to corrosion $884.00.
-Head gasket blown from overheating. Send to machine shop to see if cylinder head is warped or cracked. If cylinder head is repairable estimate will be $4380.00.
-Should the cylinder head be unrepairable there will be an additional $2,555. (includes parts and labor).
I'm wondering if its better to get a complete engine replacement and if so how much it would cost including installation.
Thanks.
Old 07-24-2011, 04:00 PM
WOW sounds like Price gouging ... I've seen others with a blown head gasket under 1k even replacing the heads at 2k
Jdgros2
02-21-2022 11:54 PM
Byron
07-08-2012 07:25 AM
06-11-2012 04:22 PM
calxen61
10-30-2010 04:40 PM
jeninTN
09-20-2009 04:00 AM
Quick Reply: Blown gasket, cost of engine replacement?
