Problems starting my wife's R52
Old Mar 24, 2019 | 10:29 AM
AlterBridge's Avatar
Default Problems starting my wife's R52
I'm hoping someone can help with this particularly annoying problem...
A few weeks ago, my wife drove home from work, parked on the drive and locked the car up. No problem. A few days later, went out to it, tried to start it and ran the battery down as it just refused to fire and she refused to give up trying until the battery gave up first.
A friend brought up a diagnostic laptop and the only (relevant) fault code was P1692 which appeared to point towards a throttle body problem; the friend decided it probably wasn't that and we explored other options.
I pulled a spark plug and turned it over - no spark.
I checked the fuel and none was being pumped to the engine.
Also, when turning on the ignition, I noticed there wasn't the usual sound of the fuel pump initialising...
Firstly, on advice, I changed the crank position sensor - no change.
I checked all of the fuses in the engine bay box and the cockpit panel - all ok (including the 40, 50 and 100 metal ones underneath the engine bay box).
I removed the fuel pump and tested that and it was fine, although checking the wiring in the multi-plug showed no feed was getting to it. The relay was soldered onto the inner fuse box, so I replaced the whole thing.
Still nothing.
I took the bull by the horns and replaced the throttle body, thinking that as the P1692 specifically mentioned that, it may be at the root of the problem...
Still nothing.
So here I am, a bunch of replacements made and no further forward. The same error code is brought up through the ODBII connector and nothing I've done has made the slightest difference...
HELP!!!!!!
Old May 5, 2019 | 07:16 PM
08ragtop6s's Avatar
Good day!
It almost sounds like your key isn't talking to the computer... No fuel pump power or coil firing... You could see if you get some life out of it if you supply the fuel, but that will only tell you if the coils are firing, not solve the problem... Do you have a way to hook up a computer to the car and see what it's complaining about?!
Cheers!!
Samkarpets
9
Jun 30, 2023 08:39 AM
RichAromaCoffeeCo
Sep 8, 2019 05:43 AM
Yaofeng
7
Jun 17, 2018 07:58 PM
thatslammedmini
Apr 13, 2015 12:57 AM
Star Thrower
Nov 16, 2014 09:15 PM
