Rear window stuck
Old Aug 13, 2013 | 07:22 PM
Camaro108's Avatar
Default Rear window stuck
Hey. I have a 2005 JCW convertible that all of the sudden, the rear right triangle window wouldn't come up anymore. It makes motor noises when the button in pressed, but it won't move. Living in Arizona, I need to get this window up! What can I do?
Old Aug 14, 2013 | 01:34 AM
DawnPreston's Avatar
Okay, I am no auto expert, but you could try the following: Dismantle the assembly and look for signs of damage. If not found, then douse the window winding motor with good old WD 40 and ditto for the switches. Should work for you as it did for my old jalopy. More inputs from veteran members would be more informative though.
Old Apr 9, 2015 | 04:50 PM
https://minicooperforums.com/forum/0...oming-up-7938/
Talked about here in the passenger side.
JIDavis
May 4, 2019 02:58 PM
lmalbright
Oct 21, 2013 09:31 PM
Camaro108
Aug 20, 2013 04:12 PM
Aug 5, 2013 04:08 PM
jazznuts699
Apr 19, 2010 01:02 PM
