08 mini cooper back window not coming up
Old Apr 7, 2015 | 10:51 AM
08minicooper's Avatar
Default 08 mini cooper back window not coming up
hi there, i have an 08 mini cooper conv and the back window will not come up, i heard a pop noise as i was bringing it back up, and now it will not come up at all, is there any way to manually bring it back up? any idea on what the cost will be to get it fixed? thanks so much
Old Apr 9, 2015 | 04:37 PM
You are in the wrong forum, You Have an R52 MINI Cooper Convertible ( Gen 1 ) 2005-2008
Sounds like the regulator:
#2 51377111018
http://www.ecstuning.com/Search/SiteSearch/51377111018/
You can try to pull it up with your fingers . You will need this tool for adjustment and to get the window glass off the mount, has a little gear nut.
Here is the new mounting set with those gears. : 51377201455
http://www.ecstuning.com/Search/SiteSearch/51377201455/
Here is the tool Window Regulator Nut Wrench 83300494251
http://www.ecstuning.com/Search/SiteSearch/83300494251/ES199501/
Thanks and watch not to break the glass so you can swap it and save the tint.
Old Sep 6, 2016 | 05:27 PM
Jim Gioffre's Avatar
Was it the regulator? I am having this problem as well. Please let me know if it was something small or the regulator.. Thanks
BluecoupeS
Feb 21, 2015 06:05 PM
Aug 5, 2013 04:08 PM
jazznuts699
Apr 19, 2010 01:02 PM
thechicgeek
Feb 7, 2009 11:52 PM
