2008 Cooper Base idle issue
I'm stumped. I purchased an abused 2008 Cooper base. N12 motor, 6 spd, 150,000 miles. Found signs of major sludge in the motor. I have done the following:
Engine oil flush, sludge is gone Pulled the pan, no signs of pump failure New OEM plugs New OEM fuel filter New OEM air filter New Vanos solenoids(they were shot) New fuel feed line (very spongy) Cleaned cam position sensors(had sludge buildup) Cleaned MAF sensor, Throttle body and intake boot. New oil pressure switch Car runs good at this point. Well, up until the motor is warmed up, and I have to stop in traffic. As soon as the car stops moving, the idle drops 100-200 rpms to about 500rpms, acts like it wants to stall, and the idiot light for oil pressure comes on. Blip the throttle to about 800 rpms, it goes away, and no rough idle. Only runs rough under this condition. At speed, full power, runs great. No codes being thrown at this point. I assume I'm chasing a vacuum leak. Any ideas? My vacuum pump doesn't appear to be leaking oil. Does anyone have a vacuum hose schematic? Everything that I have done has helped, but apparently only took care of the symptoms. |
Originally Posted by Mrrbby1
(Post 21035)
Since there was sludge, be sure to change your oil much sooner than usual now. It seems the poor MINI was very neglected. Are there any codes present in the system? If you have access to it, try to smoke test the system to make sure there aren't any vacuum leaks.
Originally Posted by PelicanParts.com
(Post 21041)
No codes coming up. Any chance of you having schematics? Lots of places for vacuum connections to hide in that tiny engine bay. |
(Post 21043)
I have changed the oil four times at this point. I plan on doing a 3k interval until I hit 160k. The oil isn't my issue at this point.
(Post 21057)
I pulled the air cleaner after starting the car, and turning it around in my driveway. I found a puddle of fuel on the intake under the injector that is next to the feed line. May I assume that a leaky injector/s would cause those symptoms?
I went to clean the connectors for the throttle body and MAF sensor, and noticed the orange wire coming out the MAF pigtail had cracked insulation, right where it exits the pigtail. Uncovered more of the harness, found the wiring still flexible and not damaged. Brittle right at the pigtail. While I search for another pigtail, does anyone know what that orange wire goes to? What input to the computer is being screwed up by this? |
thanks for the update.
That part of the wire harness that goes back to the ECU. I would see if there is a break in the harness , cut it and resolder then end then shrink heat a new plastic sleeve on. Sounds like that the issues. |
Originally Posted by ECSTuning
(Post 21100)
That part of the wire harness that goes back to the ECU. I would see if there is a break in the harness , cut it and resolder then end then shrink heat a new plastic sleeve on. Sounds like that the issues. I will try to trace the rest of that harness for any other breaks or cracks. Thanks |
Diagram #17
RealOEM.com - Online BMW Parts Catalog https://www.ecstuning.com/Search/Sit...419/ES2675556/ x 1 then https://www.ecstuning.com/Search/Sit...932/ES2672724/ x how many wire you have Then the gommet x the number of wires, this seals the wire to the plug . https://www.ecstuning.com/Search/Sit...411/ES2673549/ https://c1552172.ssl.cf0.rackcdn.com/214169_x600.jpg Strip the wire of wire back a bit, you have some room/ slack in the harness. Then cut and reclip the ends. |
