2008 Mini audio CD drift problem
Old 12-14-2010 | 02:17 PM
wellsa's Avatar
Default 2008 Mini audio CD drift problem
I've started to hear a buzzing noise when I open the door. When I began to play the radio, it sometimes drifts away from the radio to the CD player on its own (even though there was no CD in the changer). This has happened sporadically as if doesn't like the radio station I'm listening to. Has anyone had a similar problem?
Old 12-14-2010 | 04:58 PM
Is the buzzing noise coming thru the speakers ?
Old 12-15-2010 | 07:35 AM
wellsa's Avatar
Default 2008 audio CD drift problem
Thanks for the response. I checked and the buzzing noise is not coming from the speakers. It also goes a way after a short time (about 10-20 seconds). I don't actually know if the two problems--the buzzing and the drift away from radio to CD--are related. But they both happened at the same time, so I was assuming so.
GOOP
10-13-2010 10:48 AM
54CooperS
10-14-2009 02:05 PM
TeamKO
08-30-2008 12:59 PM
ziggy56
08-06-2007 07:55 PM
lushtech
08-21-2006 09:33 PM
