2008 Mini Cooper Base model/fan stays on
Old Mar 28, 2024 | 11:02 AM
emendoz1's Avatar
Default 2008 Mini Cooper Base model/fan stays on
I have a 2008 Mini Cooper Base model that has an issue with the fan. When I start the car in the morning the fan comes on automatically and stays on for about 5 minutes after I turn it off no matter how long the car was on. I checked the fuse box and there is one relay for stage 1 and another for stage 2 fan but I only have one relays installed. Maybe the other relay got removed when I took it to a mechanic, maybe it never had one. Do I need both relays for fan1 and fan 2? I replaced the thermostat and the pipe that goes across to the water pump and there are no leaks. I connected the scanner and the temp never moves form 32c (40 or 44) can't remember.
Anything else I could check?
Tounphic
Jul 12, 2024 04:16 PM
Bluenose
Jun 26, 2019 12:39 AM
tedpet
May 26, 2019 07:53 PM
daytripper540
Oct 19, 2016 07:11 PM
Riddla
Oct 5, 2008 01:39 PM
