2008 Oil filter
Old Mar 1, 2009 | 06:51 PM
calxen61's Avatar
Unhappy 2008 Oil filter
Where is it, how do you get it off?
thanks
cal
Old Mar 1, 2009 | 07:30 PM
Mini's use a canister type filter it's on the upper passenger side under a black canister , you'll need a 27mm wrench to loosen it and a T50 to drain the oil
Old Mar 1, 2009 | 07:38 PM
calxen61's Avatar
Mine is and 08 do you get to it from under the car?
thanks
cal
Old Mar 1, 2009 | 08:09 PM
The 08 is the same 07 ... And NO it's loosened from the Top (Oil Filter)
Drain Plug is underneath
Old Mar 2, 2009 | 11:19 AM
calxen61's Avatar
I have looked at it from the top of the motor on the passengers side under the hood. Yet all I see is air hoses, how about a better description before I start taking things apart.
thanks
cal
Old Mar 2, 2009 | 04:26 PM
calxen61's Avatar
Default Got it
thanks
cal
I found it, it is actually under the water tank on the drivers side.
thanks all
cal
supanatral
Jan 10, 2012 02:55 PM
headhunter92
Oct 4, 2011 04:35 PM
kmwatersaz
Sep 14, 2010 08:11 AM
jball
Dec 2, 2009 04:15 AM
Coopermini
Oct 17, 2008 08:51 PM
