-   -   2008 Oil filter (https://minicooperforums.com/forum/07-up-mini-cooper-cooper-s-r56-31/2008-oil-filter-1847/)
calxen61 Mar 1, 2009 06:51 PM
2008 Oil filter
Where is it, how do you get it off?
thanks
cal
bad venge Mar 1, 2009 07:30 PM
Mini's use a canister type filter it's on the upper passenger side under a black canister , you'll need a 27mm wrench to loosen it and a T50 to drain the oil
calxen61 Mar 1, 2009 07:38 PM
Mine is and 08 do you get to it from under the car?
thanks
cal
bad venge Mar 1, 2009 08:09 PM
The 08 is the same 07 ... And NO it's loosened from the Top (Oil Filter)
Drain Plug is underneath
calxen61 Mar 2, 2009 11:19 AM
I have looked at it from the top of the motor on the passengers side under the hood. Yet all I see is air hoses, how about a better description before I start taking things apart.
thanks
cal
calxen61 Mar 2, 2009 04:26 PM
Got it
thanks
cal
I found it, it is actually under the water tank on the drivers side.
thanks all
cal
