Check out our M7 TUning Aerogel Turbo Heat Sheild!
TODAY'S FEATURED PRODUCT
M7 Aerogel Turbo Heatshield 2 (R56, 2011+) MINI Cooper
Get if for only $199.00!
The M7 Aerogel Turbo Heatshield is better than anything else on the market for a number of reasons:
It does not completely encase the turbocharger as some have assumed (the turbocharger is actually fully wrapped in its own, ineffective heatshield). The M7 heat shield still has openings for air to escape down and away from the turbo. The majority of heat that wants to rise will be absorbed by the aerogel blanket.
Aerogel is widely known as a thermal insulator which reduces the rate of heat transfer, thus making it a perfect way to keep turbo heat from reaching the rest of the engine bay.
Despite any material's resistance to heat, given enough time or higher temperatures (due to hard driving), the material will eventually heat up. Thus, the addition of aerogel is a huge benefit to the M7 heat shield as it will delay the time it takes for the metal portion of the heat shield to heat up.
The M7 heat shield is installed with two bolts going into the factory turbo heat shield. Installation does NOT require you to undo the bolts to the engine's valve cover. Any product that has you do so will make you break the seal between the head and the valve cover where incorrect installation can result in a poor seal or even a cracked valve cover.
M7: MINI Cooper Performance Parts
M7Tuning
Jul 15, 2013 07:58 AM
M7Tuning
Jun 21, 2013 10:31 AM
M7Tuning
Jun 18, 2013 09:17 AM
M7Tuning
May 24, 2013 10:36 AM
