Clicking/Ticking with low speed tight turns
Old Sep 25, 2013 | 01:04 PM
Thirdorb's Avatar
Default Clicking/Ticking with low speed tight turns
Hi all,
I have a 2009 Cooper S with about 50K miles. In the past few months I've noticed a repetitive Clicking/Ticking with low speed turns, like in a parking garage or parking lot.
I took my car to the dealer and they said they couldn't find a problem, and that it could just be my power steering pump clicking with the wheel turned to end range. They also said my front lower control arm bushing rubber was cracking, but didn't seemed concerned.
Ultimately, I am concerned there might be a bigger problem...What do you guys think?!
Old Sep 25, 2013 | 03:36 PM
nivek111070's Avatar
possibly sign of shaft bearing ? my Audi did this when it turned, i replaced the "axle" on the front and it solved it, but when i took it apart is when it was apparent, the boot had cracked and let all the grease sling out, might also consider checking motor mounts to see if they are still strong and not all weak and tore up
YahooTech
Oct 28, 2015 06:26 PM
PattyB
Jun 10, 2013 01:28 PM
LuxxLady
6
Aug 7, 2011 05:58 AM
philraine
May 26, 2011 02:43 PM
durst autosports
Jul 28, 2009 02:56 AM
