-   -   Codes Throwing After Start Idle N12 (https://minicooperforums.com/forum/07-up-mini-cooper-cooper-s-r56-31/codes-throwing-after-start-idle-n12-7878/)
pmarketingsales Mar 21, 2015 10:25 AM
My first post here. Love Mini's! They rip! Fun cars to drive!
Having issue with my Cooper. 2008 N12 engine.
After you start it the engine seems to run in a high idle mode for a moment to warm the engine. It seems that the moment it drops out of that high idle it doesn't like what it sees and it throws the code P0015 or P0014.
Pulled off valve cover and checked timing chain tension, guides, the timing, and every thing seems to check out ok. Both vanos solenoids are good, as well as their wiring to the ECU. It looks like the timing chain and Exhaust cam adjustment unit have been changed. The chain tensioner is also the updated version with the dimple in it.
I also checked pressure to depress the tensioner and it took a 35lb dumbell to depress it.
Anyone have any ideas as to why the computer is sensing advanced or retarded timing on my exhaust cam? Car has 100k miles on it.
I'm lost on this one.
Oh cam sensors are both good also, as well as their wiring to ECU.
