Cylinder Misfire
So I will try and keep this short.
A Few days ago my car threw an engine code. Cylinder one Misfire. I Swapped coil one and coil two. Cylinder two Misfire. Great, the coil is bad. I replaced the coil. After the coil is replaced, i drive the car. The Car feels better then it has in awhile. Two days of driving later, i get an engine code. Cylinder one Misfire. On top of that i'm getting codes P2781 [ECU7E8] (Downshift Switch Circuit high) and P2771 [ECU 7E8] (Four Wheel Drive Low Switch circuit) My car is a 6 speed stick, not automatic. Do I have a bigger issue or did I just get unlucky and have two coils fail close together? |
| All times are GMT -5. The time now is 07:42 AM. |
