Evu problem
Old May 13, 2022 | 07:01 PM
Keithr83's Avatar
Default Evu problem
2008 nini cooper base- std trans! Evu replaced as it was showing ignition miss on cyl # 1I installed the ecu and the part under the dash pad! These parts came with a compatible key fob- there is no communication between the fob and system/it looks like the battery in the fob is dead! It is a completely sealed fob! What can I do at this point?
Old Jun 14, 2022 | 08:22 PM
BULLDOG85043's Avatar
Did you try putting the fob into the holder for a bit to try charging it? Those internal batteries don't hold a charge forever and are recharged while you're driving along.
Chipper
May 20, 2018 01:49 PM
bburke
Sep 15, 2016 12:47 PM
sirron
Aug 22, 2014 05:23 PM
jfoderaro
Jul 24, 2011 11:03 PM
missik999
Sep 2, 2010 07:59 PM
