Fog Light Installation
I just purchased a 2007 R56 Mini Cooper. It does not have the in bumper fog lights only the parking lights. My question, is it prewired for the Fog lights and switch? I was hoping by purchasing the correct lights, brackets and switch panel I would not have wiring to do, any info is greatly appreciated.
If you do not already have any pre-wiring you will have to add it. Yours is just a base Cooper and not a Cooper S correct? If so, I believe you might already have the harness for the fog lights even though yours did not come with them. If you confirm you do it would only require installing a toggle switch and then having a dealer or indy shop do the activation with programming.
Here are the DRL LEDfog lights - MINI daytime running lights LED| Pelican Parts You'll also need 2 of these if you do not have the fog light option as this will enable you to attach them - Bracket For Front Fog Lamp | Pelican Parts Or just the normal fog lights here - http://www.pelicanparts.com/catalog/...pg6.htm#item24 |
Thank you for the info. It is a Base and not the S.
| All times are GMT -5. The time now is 03:05 AM. |
