Help! Can't figure out source of coolant leak
Old Dec 26, 2019 | 10:54 PM
Arron Alsman's Avatar
Default Help! Can't figure out source of coolant leak
I have a 2010 cooper base that has a coolant leak. Its on the right side of the car just inside of the tire. I've replaced the water pump and coolant pipe and the car still has a leak. I can't find the source of it. I also broke the crakcase breather hose which is plastic and was wondering if i could replace it with a rubber hose. Any help is appreciated. Thanks in advance
Old Feb 5, 2020 | 11:29 AM
j911brick's Avatar
Did you ever figure this out?
Old Feb 6, 2020 | 06:23 AM
I changed the coolant pipe but did not put gasket maker on the water pump end. It was leaking from there
yosteff
May 6, 2019 11:45 AM
Howells
Jun 26, 2018 01:26 AM
yeti10
Apr 28, 2018 05:51 PM
gibbo
Jun 18, 2014 09:49 PM
oldbuckman
Jan 3, 2011 08:09 PM
