high pressure fuel pump
Anyone experience misfire problems assocaited with a bad high pressure fuel pump? I am having to replace mine and the cost is over $1200.
thanks |
fuel pump
That's dangerous bro. Well, at least you did replace it immediately. Always try to double check your fuel pump assembly once a week in order to avoid it before it's too late.
I had mine replaced under warranty after 1 year. Now Mini has extended the warranty on the pump on 2007 - 2009 models for 10 years or 120,000 miles.
| All times are GMT -5. The time now is 07:46 AM. |
