-   -   How to remove the rear drive shaft on a 2012 Countryman ALL4 S (https://minicooperforums.com/forum/07-up-mini-cooper-cooper-s-r56-31/how-remove-rear-drive-shaft-2012-countryman-all4-s-8522/)
bumanng Sep 10, 2015 04:45 PM
I'm rebuilding a 2012 Countryman ALL 4s. I need to separate the rear drive shaft from the transfer case. For the life of me I can't figure out how it comes apart. I called the dealership to ask for advice. Apparently spending $4300 at the parts counter doesn't buy and "good will) at the service department. Any help would be appreciated.
PelicanParts.com Sep 11, 2015 10:10 AM
Next time you need parts, check out our online parts catalog here. Should save you some money. I remember assisting someone on this for their All4 not too long ago. See if it may be helpful, you can view it here.
bumanng Sep 11, 2015 09:48 PM
I actually found a PDF file on line at the following link that tells how to get it off.http://www.defivfabrication.com/install/rrpropshaft.pdf
