Mini cooper crank but does not start
Hey guys,
I need your help please with this 2009 Mini Cooper Base N12 issie. The car crank but does not start ( please chdck the youtuYo video below: I bought the car like that and so far I done below: 1-battery fully charged and its from ankther running N12. 2- checked all relays and fuses. 3- replaced the spark plugs and coils with the other running N12 I jave. 4- removed the engine head and everything looks tighten and clean , no broken bridge or weird sign on the chain. 5- the engine spins when I spin it clockwise. I also did compression test but the device did not show any signs of compression and I don't know if the device is working. Fuel pump seems workjng bc there are gas in the spark plug area when I removed them ( they were wet and I waited until they dried to elimenael gas flood possibility). |
Where are you located?
What codes are you getting? |
Originally Posted by Minitobe
(Post 24981)
Oh wow...engine replacements are the killers. I wonder if it could've beem saved? Are you also on northamericanmotoring.com?
Im in philly and do work on minis as a hobby. |
(Post 24987)
Im in philly and do work on minis as a hobby. Rebuilding an engine was costing me around 1000$ and I had a N12 salvage Mini that I was not able to sell it for even $1500. So it was ideal for me to swap the engine and sell the salvage one with faulty engine. |
Makes total sense!
| All times are GMT -5. The time now is 09:16 AM. |
