Mini Cooper S R56 Ecu Tuning
Hello everyone
Im lucky to own a R56 S with the N14 engine. Currently im looking to get an ECU Tune Im running a dp decat full straight pipe, K&N panel filter an Airtec IC , NGK spark plugs. Soon i ll buy the BOV which will probably be a Forge one. I wanted to ask you about the Tune What parameters should be taken care of in order for the car to work properly and without problems..? For example : Should the thermostat temperature be lowered? What else should i be aware of? |
| All times are GMT -5. The time now is 12:42 AM. |
