moon roof sticking
Old Apr 8, 2008 | 09:32 PM
slhess57's Avatar
Default moon roof sticking
Are any of you having trouble with your moon roof opening? Mine seems to stick on days when it is warm. I am wondering if this is common or do I need to have this looked into?
Old Apr 30, 2008 | 02:57 PM
jvanlee1's Avatar
Default RE: moon roof sticking
Mine also. Starts to pop up, then closes. If I push up on the rear of the front panel, it goes up OK. Something for my next visit to the dealer.
Old May 9, 2008 | 09:34 AM
chris410's Avatar
Mine has done this a few times. It opens fine however, on closing it will close then pop-up once in a great while. I just hit the button forward in small moves and it closes just fine. I suspect there is pollen or something getting on the sensor. Not sure to be honest but as far as function is it ok. As of now it isn't anything I am concerned about but if it continues I will probably take it and have the dealer look it over.
Old Aug 12, 2008 | 07:08 PM
Dunhill's Avatar
I have a 07 mini and just went through the same problem.What worked for me was to get a good quality white grease and lube up all the contact points where the roof slides on.What i was told was that with the car sitting in the sun, the roof heats up, expands and the glass roof tends to bind.Havent had a problem sence.
Hope this helps.
Old Sep 20, 2008 | 04:40 PM
mywifedrivesamini's Avatar
My Mini has been in the dealership twice for this, and is scheduled for a third time soon. As Dunhill said, the roof heats up in the sun, but they told me it was the rubber around the glass that expands. I'm going to try adding lube to the tracks.
Old Oct 2, 2008 | 06:22 PM
ymperformance's Avatar
remove front and rear glass and lube all contact points
Feb 21, 2014 03:37 PM
artlessone
May 5, 2011 09:13 AM
Technique
Dec 17, 2010 06:39 AM
mtnmini
May 29, 2008 06:44 PM
rountree54
Nov 22, 2006 11:52 PM
