newowner questions
Was reading the manual today and noticed it said that the mini comes with some sort of maintanence program for 36mo/36000miles. does that include oil changes and would that transfer to second owner(me)? Also it has the run flat tires on it, when the tires need replaced do they need to be replaced with run flats or can regular tires be used?
Dealer can tell you if there is coverage likely you might be close to running out
Regular tires CAN be used but remember there is no spare so get a tire plug kit and a compressor or tire mobility kit or AAA card or pay for towing insurance |
ours has the donut spare. I didn't beleive it at first but there is one under the rear of the car. thanks for the reply, guess i will call original dealer monday
Originally Posted by GCooper
(Post 11491)
Mini Covers maintenance/ oilchanges and replacement wiperblades
Originally Posted by bad venge
(Post 11486)
I had a question I have a 2005 Mini no S(auto), I had the check engine light come on and where you see the "D" for drive in the speedometer there are the letters"EP". Does anyone know what this means? I hate to take it in for service for something I can fix. If I went in for service every time the check engine light came on I would live at the dealer.
I just bought a 2011 Convertible S last week. I was told it had "run flat" tires. If there is a spare tire, where would it be?? thanks for your help
My understanding is NO S cars have the spares or convertibles.
Some coopers have spares although I have never seen one with I |
Spare Tire
Just bought an '11 Mini base and was told only the base Cooper has the spare. The "S", based on the configuration of the exhaust (dual and center exit), has no room for one.
