Oil Change - Added 5 Qts??
Old Nov 9, 2010 | 10:56 AM
rfstocker's Avatar
Default Oil Change - Added 5 Qts??
Hi, I just joined this forum ... I have a 2009 Mini Coupe Base. I just changed my oil according to a member's instructions and I'm now finding that there's so much conflicting information on the net about the amount of oil to put in a Mini R56 engine. I just added the 5 quarts as the member's instructions called for.
Now I am not sure if this will damage the engine. I did completely drain the crank and change the filter ... so ... what is the consensus on 5 quarts of oil?
Will I damage the engine? Please help!! I am the world's biggest worrier
Old Nov 28, 2010 | 08:06 PM
automan21's Avatar
what does it say in the manual about the amount? Dont these engines require alot of oil so they wont have that cold start chatter? You wont ruin the engine with too much oil just the cats and oxy sensors.
Old Nov 29, 2010 | 11:26 PM
Spiderbob's Avatar
And what does the dip stick show? It can be over the upper limit by what looks like a 1/2 quart with no problem.
WHITE07
9
Mar 4, 2010 07:58 PM
bmwmigration
Mar 30, 2009 04:42 PM
Blackfoot
May 31, 2008 02:17 PM
devlogos
Mar 6, 2008 08:47 AM
Leetle
Jul 12, 2007 08:15 AM
