Overboost (sport) numbers
Old May 14, 2008 | 08:25 AM
chris410's Avatar
Default Overboost (sport) numbers
I read that in the sport mode that there's an overboost feature which brings the torque up to 192ft/lbs momentarily. However, there's no mention of the HP. Does anyone know what the HP numbers are with the overboost feature engaged? Having owned a few turbo charged cars and tuned them tells me that typically, the HP numbers are far greater than the torque.
For instance, my previous car which was a 1997 Toyota Supra Anniversary 6-speed put down 597 RWHP and 555 ft/lbs of torque on low boost running pump gas. Needless to say I upgraded the turbo :-). Every single time I dynoed the car the HP VS torque was usually around 7% to 8% of the torque.
So if I had to guess going by past experience the HP number would be around 205HP (crank) going by 7%. OR...going by stock numbers 192ft/lbs = 190hp? Since stock the numbers are 177ft/lbs and 175hp (however things change drastically as boost is increased) Has anyone dynoed or gotten numbers to confirm this? Also, does anyone know how much the boost is increased? I know when I switch the car to sport mode that it is a noticeable difference so I was curious.
-Chris
minifun
Jul 26, 2011 12:57 PM
Parker Fillmore
Aug 18, 2008 08:27 PM
popelofe
Jun 16, 2008 11:11 PM
snookhunter
Apr 5, 2008 08:48 PM
DomozitoLK
Feb 4, 2008 01:25 PM
