R56 JCW Remove oil cap = Bad idle p
Old Jun 9, 2021 | 03:49 PM
R56JCW2009's Avatar
Default R56 JCW Remove oil cap = Bad idle p
I have a vacuum issue. Loads of vacuum. Oil cap is sucked down. Remove oil cap the engine has bad idle and can die. Already changed valve cover and intake valves are clean. Replaced throttle body gasket already, charge pipes are not leaking. Ordered turbo pressure convertor from ebay hopefully that works. Any Idea's?
vandyke1475
May 25, 2021 08:37 PM
jamie
Oct 24, 2017 08:46 PM
Mrrbby1
11
Jan 21, 2016 08:45 PM
barraman
Jan 15, 2016 05:35 PM
Supraman
Nov 19, 2015 10:14 AM
